Rendering Cube Map x, y, z Flips Scene in Octane Camera
C. RAM Capacity (i.e. 6 GB)
- paride4331
Hi solomonfl,
The notified problem is not a bug .
The cube map is a projection of a cube, then you 'll see the flipped.
You 'll see your render properly with Vr viewer.
Correct. This is the format Carmack suggested for quick mapping to GL cube map on load.paride4331 wrote:Hi solomonfl,
That's not the case in Unity ~ when I render the images and use them on a Skybox, they stay flipped as they were in Octane. I am using the 6 sided option for the skyboxGoldorak wrote:Correct. This is the format Carmack suggested for quick mapping to GL cube map on load.paride4331 wrote:Hi solomonfl,
Baked from cube with inverted rayssolomonfl wrote:is there a way to render without forcing it to mirror the render?
- paride4331
Hi solomonfl,
when you will bake your cubemap on the cube,
in unwrap keep in mind to follow the following order: X- X+ Y- Y+ Z- Z+
To invert the cubemap check the Revert command in Ocantecamera modifier.
Thanks Paride4331, So what are the steps you go through from switching to Baking to the final render?paride4331 wrote:Hi solomonfl,
in unwrap keep in mind to follow the following order: X+ X- Y+ Y- Z+ Z-
There was an earlier post on the forums covering this approach. I am going to have to look it up.
