Octane Properties are cleared when open old scene
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
akira
A. Operating System Win10 pro
B. Graphics Card(s) GTX780 x2
C. RAM Capacity 6GB x2
D. Nvidia driver version 372.90
E. OctaneRender Standalone version, if installed 3.03.4
F. OctaneRender plugin version 3.03.4_4.18
G. Host application version, including build number if available 3ds max 2016 18.0 sp3
Hello! I started testing the automatic material conversion that came with 4.18, and found a issue:
Every object's octane property(especially those proxy sources) is not converted as it was, and all value were set to empty.
the max scene was made by max 2013 + OctaneRender for 3ds Max 2.23.2 - 1.9
i think these properties should be converted too.
akira.
HHbomb
same here.
Some bitmap disappeared too, but I don't know how original materials were made. Need investigation.
paride4331
Hi, akira
I verified and reproduced the issue you had.
I encountered the issue you had in Version 2.23.2 - 1.9
but not with the latest stable version 2.225 - 2.22
I also had the same issue when I open a 2.23.2 - 1.9 file
with the latest stable version 2.225 - 2.22.
I think the issue you had is caused by the 2.23.2 version - 1.9 and not by 3.03.4 - 4:18
can you confirm this through a test please?
akira
paride4331 wrote:Hi, akira
Hi
I heard that 4.18 can convert old 2.23.2 - 1.9 materials internally without those 2-stage converter scripts.
So i installed 4.18 and try to open max scenes made by 2.23.2 - 1.9 and this issue happened.
paride4331
Hi, Akira
I will send a file with the issue to developers Octane 3ds max plugin.
Thanks for your contribution.
neonZorglub
Hi Akira,
Thanks for the feedback.
This issue is now fixed in the new 4.19 release.
Go to the 'Tools' tab fist, activate the conversion system and restart max to have the converter enabled.
Let us know if you have other issues.
neonZorglub
akira
neonZorglub wrote:Hi Akira,
neonZorglub
Thank you for fixing this so quickly! It works like a charm now.
But Max will crash if you try to open a 2.23.2-1.9 scene without activating the converter in tools tab first.
paride4331
Hi Akira,
I tried to reproduce your issue, but I have not encountered any crash.
Could you share, even privately, a scene makes the same mistake?
thanks for your time.
Return to “Bug Reports”
