I'm using a image sequence (32bit PSDs) inside the Octane Texture Environment but the Live Viewer does not update to show the animated texture.
Yes, I set the proper image range in the Animation tab.
For some reason, It only updates when I toggle on and off Imp. Sample within the Env tag.
Seems like a bug.
Thoughts?
Environment with animated HDRI texture
C. RAM Capacity (i.e. 6 GB)
There cannot be a bug like that 32bit-psd doesn't work but 16-bit works. Sorry this is my thoughs. There is not any difference on handling of formats for animations or else. It should work on sequences if it works too for single frames.
Do you have something to show this?
- [email protected]
Hey - i attached a project file with animated texture included. You'll see what I mean.
32bit animated PSDs do work, but It only updates in Live Viewer when i toggle the Imp. Sample on and off.
It would be great if live viewer updated the Environment image sequence when scrubbing the timeline.
Thank you for looking into it.
- 32bitAnimTextureTest.zip
- (86.32 MiB) Downloaded 394 times
Are you on OSX? What's this parameter on you?
- a1.jpg (22.14 KiB) Viewed 4438 times
- [email protected]
That did it! Much thanks! No bug after all.
- [email protected]
May I ask what the rest of your Settings/Other look like?
