OctaneRender for Carrara 3.03.04.23[Stable]
Carrara (Integrated Plugin developed by Sighman)
Sighman
Did you have the octane render viewport open when you were selecting or moving the marquee? It is always a good idea to close the ORVP when making large scale changes like this.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
protovu
Hi Simon,
I did not have an open Octane viewport for this error. Are you able to duplicate with the file I provided?
Also, today, the trick of holding the shift key down to try to get around the error is not working.
I have uploaded a very simple file which seems to definitely point to an Octane Materials issue. It is a sphere with Materials from the problem file.
Once the Materials were pasted into the new file, the problem presents itself.
Please check it.
dual xeon
2 titan x
1 gfx 970
win7
simplified error when marqueing in sequencer.zip
(21.85 MiB) Downloaded 409 times
Sighman
protovu wrote:Hi Simon,
Please check it.
New update posted to this thread. This issue should be fixed now.
protovu
Seems good on initial testing. Thank you!
Nod64
Hi there,
I've had a problem with the last few versions crashing Carrara. Octane will run once to register, but when running, I get the attached message. After that, Carrara refuses to load new scenes, and I have to uninstall the Octane plug-in if I want to create a new scene.
Error occured opening OctaneRender Window: threadName=",
appartmentState='STA', isBackground='True', Configuration system failed
to initialize
Noel
Windows 10
8GB
GeForce GT 630M
Version 368.81
Carrara 8.5.1 Build19 64 bit
OctaneRender for Carrara version 3.03.04.22
Sighman
Nod64 wrote:I've had a problem with the last few versions crashing Carrara. Octane will run once to register, but when running, I get the attached message. After that, Carrara refuses to load new scenes, and I have to uninstall the Octane plug-in if I want to create a new scene.
to initialize
It looks like you might have a corrupt settings file. Please try to locate and delete all the plugin user.config files located in your AppData directory:
Mine were located here:
C:\Users\Simon\AppData\Local\DAZ_3D,_Inc
Within that directory you should find sub directories that look something like 'DefaultDomain_Path_g2zzw5wbksxx0yrpq5z0fnxllbxkqvav'. Just delete any that you find and then restart Carrara.
Note that the AppData directory is hidden by default so you will need to go into Explorer settings to make it visible:
Open explorer. Select the View tab. Enable 'Hidden Items'.
Hidden Items
Hidden Items
Nod64
Hi there,
That did the trick.
Noel
protovu
Hi Simon,
Can you confirm if something is in the works regarding noise reduction or de-noising with the Carrara Octane plugin?
Sighman
I'm not doing anything plugin specific. When octane supports it, I'll add support in the plugin.
protovu
Nice to know, thanks.
Do we know if Octane has anything in the works in this regard?
Return to “Carrara”
