Texture resolution is not working 3.03.4.-18
C. RAM Capacity (i.e. 6 GB)
- Elvissuperstar007
- Contact:
- paride4331
Hi Elvissuperstar007,
I would not think an Octane bug.
Have you tried the same test using the scanline render?
The issue you refer persists.
Do that in Render settings ..Elvissuperstar007 wrote:Texture resolution is not working
Mat. preview W/H set it like 2000x2000
turn off display textures on viewport than turn it on again..
that should then work..
it was a silly workaround from the start up.
I already asked Neon to correct that mistake. Hope this will be heard
My Portfolio
