gradient adhesive film on glass
aquelito
Hello there,
I need your help to reproduce that kind of gradient adhesive film on glass :
Thanks a lot !
Win 10 / XMG Core 14 / dGPU GTX 1650 + eGPU RTX 2070 Super / Octane for Sketchup
renderingz
Set up two specular materials, one rough one smooth, put them in a mix material and use a gradient in the texture slot to mix between the two.
Win `10/ Cinema 4D R17 / 2 x 780 GTX 6GB + 2 x 980ti
aquelito
Thanks for the answer.
Default specular material with a gradient PNG loaded in the Transparency alpha channel works pretty well too.
whersmy
I would try a mix material setup, works wonders, and you can adjust the slope accordingly real time
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
Seekerfinder
whersmy wrote:I would try a mix material setup, works wonders, and you can adjust the slope accordingly real time
Great effect!
aquelito
That's very clever, thanks !
I get that result however, no gradient effect...
What did I do wrong ?
Hi aquelito,
what happen if you rotate the camera around the material-ball object?
Do you see the gradient?
ciao beppe
aquelito
Hi Bepe
This is what I get : apparently no gradient is showing up :(
check the Saw wave node projection, probably the issue is there :roll:
ciao beppe
aquelito
Whersmy, could you please share the .ocs file ? I cannot get it to work, even with Beppe advice...
