I am trying to use a scattering medium to get some feedback on light distribution from a spotlight.
With the sunlight environment the scattering works, ie. a fog effect, but I don't get any visible light from a black body emitter with the same scattering medium settings, whether I use an ies file for distribution or not. I was hoping to see a cone of light in the 'fog'.
Ben
Visible light
I couldn't get this to work either, so have asked Otoy for guidance.
Thanks Paul
Otoy provided the clues for this. I have the Rhino scale set to "Big"", so my geometry emitter was 100m. That required a Medium Radius of 300m. Also set the Medium Absorption and Scatter to White, and it works nicely.
Thanks Paul,
Set Rhino scale to big ?
You mean scale everything up so the light has a minimum radius of 300 meters in radius ?
I tried it but no luck yet - would you be able to send me a sample file ?
Cheers,
Ben
Cheers,
Ben
The Medium Radious will depend on the scene units. Pls see example attached.
- 3.03.4 medium from emitter.zip
- (38.54 KiB) Downloaded 310 times
I think that is the particles (medium) rendering rather than noise.
