OctaneRender 3 for Modo [OBSOLETE]
Modo Box Projection mapping translates automatically to Octane Box mapping.
MrFurious
smicha wrote:
MrFurious wrote:I think this is the video you're referring to, It all makes sense I just can't figure out how to apply it in this case
I'll try it today later on.
Many thanks but I went with cubic mapping until I have time to have a closer look at this.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
Dmi3ryd
Sometimes render region tool and image pan does not work. It's loked after I press right or left mouse button it can help or sometimes not. :(
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
MrFurious
I also have this issue sometimes, it seems to help if you click the border of the preview window and try again to drag / pan / zoom.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
face_off wrote:Modo Box Projection mapping translates automatically to Octane Box mapping.
True it does. the issue was that I imported a cad file which for some reason the mapping (cubic and box) did not appear to map correctly in openGL, After unparenting and 'freezing' all items, all was good.
Dino Inglese
CG Artist
Melbourne Australia
yaseunghee
UDIM support problems.
I had try to apply udim normal files in V 3.03.3 but i didn't work.
So i downloaded V3.03.4 test version. but i didn't work, too.
uploaded images are v3.03.3 but texted messages are same in V3.03.4.
I had done some efforts to change my files suffix or change file type(ex. png, tga, psd...) but all to fail.
Try making the filename one character longer (ie. "NN1001.jpg"). I think the plugin is erroneously throwing an error if there is only one character in the filename (which is not the tile numbers).
yaseunghee
Unfortunately, it doesn't work..
I had changed my files name which have more characters, but it doesn't work.
The 4 digits of the UDIM tile number need to but at the end of the filename.
yaseunghee
I had change my file names various styles. like "normal_1001", "egg_normal_1001", "eggnormal1001".....all efforts are failed.
I don't know why can't apply it..and modo octane render always texts same message...
I solved this problem manually.
i use 'image still->uv->udim' option.
handling manually udim U and V coordinate and uv textures.
but still want to handle auto ways like your tutorial..
Return to “Foundry Modo”
