Struggling with Sparklexs of a sort.
Moderator: BK
Hydra
Hey, I'm struggling to get a render to work.
I'm just working with this;
http://www.daz3d.com/designer-bedroom
Try as I might, I always have sparkles on the wall. By default my renders use Caustic blur = 1, and GIClamp = 1.2.
I've tried lots of variants.. reducing Ray Epsilon, messing with the lights, even IES lights.. I get sparkles around the surfaces, and I get the most annoying halo around the light on the wall.
This particular render ran to 1000 samples. Any ideas guys?
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
Veneris
Increases "Sampling Rate" of the material of the light source.
And you need to play with this options:
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
Because there is not much light in the scene, you could also lower the Kernel Path Termination Power. And you can also add spheres over the lights, and make them diffuse emitters with an opacity of 0, so there are large geometry items emitting the light.
Return to “DAZ Studio”
