I'm trying to mix 2 displacement map, drived buy a another map. But this doesn't work.
With mix texture displacement don't work. Same using mix material node.
Any idea?
Mix displacement
Sorry, currently the displacement only works with the texture image node. No other nodes can be used, including the texture mix node.
One workaround can be use the procedural input to rasterize the textures mixed using LW nodes, but I'm not sure if this workflow could be useful for you.
https://docs.otoy.com/Lightwave3D/?page_id=564
