Mix displacement
scratch33
I'm trying to mix 2 displacement map, drived buy a another map. But this doesn't work.
With mix texture displacement don't work. Same using mix material node.
Any idea?
juanjgon
Sorry, currently the displacement only works with the texture image node. No other nodes can be used, including the texture mix node.
One workaround can be use the procedural input to rasterize the textures mixed using LW nodes, but I'm not sure if this workflow could be useful for you.
https://docs.otoy.com/Lightwave3D/?page_id=564
scratch33
Ok, thank you Juanjgon,
I'm going to test your workaround and see if this work in my case.
Francesco
Return to “Lightwave 3D”
