HI!
I'm having serious problems with rendering in build 3.03.3.0 (LW plugin)
It starts rendering and then after minute, two or 3 it just gives up, Windows screen freezes for 3-4 sec (sound works fine in BG so it's only GPU lockup). It's always different GPU (it's not hardware issue). Sometiem it says GPU given up or some such silly message.
I use latest 372.54 driver from nvidia, Windows 10 64bit AU (Anniversary Update) and Titanx+2* GTX 1080.
My windows registry TRDelay setings show this: value "0x0000000a (10)" . That owudl mena it's already set to 10 seconds by default ?
Please HELP, i need to finish this job and i cant' render anyhtign more than 4-5 minutes (t's not overheating or so, GPUs are 55-72 C). Thanks
Here is part of octane.log:
00:01:59 (0119.25) * OCTANE API MSG: CUDA error 719 on device 0: unspecified launch failure -> failed to bind device to current thread
00:01:59 (0119.25) * OCTANE API MSG: device 0: failed to initialize resources
00:01:59 (0119.25) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:01:59 (0119.25) |
00:01:59 (0119.25) | ++++++++++++++++++++++
00:01:59 (0119.25) | +++ RENDER FAILURE +++ processing the failure callback
00:01:59 (0119.25) | Aborting rendering detected
00:01:59 (0119.25) | >>> Refresh preview window
00:01:59 (0119.25) | >>> Draw preview window information
00:01:59 (0119.25) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure
00:01:59 (0119.25) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> failed to bind device to current thread
00:01:59 (0119.25) * OCTANE API MSG: device 2: failed to initialize resources
00:01:59 (0119.25) * OCTANE API MSG: device 2: failed to recover - giving up and switching device to failed
00:01:59 (0119.25) | >>> Draw preview window status
00:01:59 (0119.25) | >>> Draw preview window progress bar
00:01:59 (0119.25) | >>> Draw preview image
00:01:59 (0119.25) | >>> Draw preview image finished. Releaseing mutex
00:01:59 (0119.25) | >>> Refresh preview window done
00:01:59 (0119.26) | >>> Draw preview image finished. Releaseing mutex
00:01:59 (0119.26) | ... Finish Rendering ...
00:01:59 (0119.26) | ... wait for the getPreviewImage function ...
00:01:59 (0119.36) | ... reset image callback ...
00:01:59 (0119.36) | Close and free scene, free buffer: 1, reset scene: 1
00:01:59 (0119.36) | ... freeBuffers
00:01:59 (0119.37) | ... setRenderTargetNode(NULL)
00:01:59 (0119.47) | ... update()
00:01:59 (0119.47) | ... getRootNodeGraph()->clear()
00:01:59 (0119.52) * OCTANE API MSG: CUDA error 719 on device 1: unspecified launch failure
00:01:59 (0119.52) * OCTANE API MSG: CUDA error 719 on device 1: unspecified launch failure -> failed to bind device to current thread
00:01:59 (0119.52) * OCTANE API MSG: device 1: failed to initialize resources
00:01:59 (0119.52) * OCTANE API MSG: device 1: failed to recover - giving up and switching device to failed
00:01:59 (0119.77) | >>> Refresh preview window
00:01:59 (0119.77) | >>> Draw preview window progress bar
00:01:59 (0119.77) | >>> Refresh preview window done
00:01:59 (0119.77) | Scene closed
00:01:59 (0119.77) | Close preview window
00:01:59 (0119.77) | Octane Render for Lightwave, end of log system
Yesterday i was getting different messages but same result:
"00:04:19 (0259.61) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> failed to deallocate device memory
00:04:19 (0259.61) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> could not get memory info
00:04:19 (0259.61) * OCTANE API MSG: CUDA error 719 on device 2: unspecified launch failure -> failed to unload module
00:04:32 (0272.74) | IPR: abort render thread command finished
00:04:32 (0272.74) | Close and free scene, free buffer: 0, reset scene: 1
00:04:32 (0272.74) | ... setRenderTargetNode(NULL)
00:04:32 (0272.74) | ... update()
00:04:32 (0272.74) | ... getRootNodeGraph()->clear()
00:04:33 (0273.00) | Scene closed
00:04:33 (0273.00) | IPR: free the snapshots system
00:04:33 (0273.00) | IPR: IPR preview window closed
00:04:33 (0273.00) | Octane Render for Lightwave, end of log system"
CUDA 719 Issues !
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
- BorisGoreta
- Contact:
I don't understand any of this but it seems you jumped to 1080 a bit too early.
Not really Pascal issue 'coz it happens sometime with TitanX and 780 6GB OC also.
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
Hmm, it seems some foliage instancing is tripping it over, when i remove 3D instanced grass (100k grass patches) then it renders. Then i added some more trees and now it's aborting/crashing again. Maybe Opacity/clipmaps is making problems for octane. Any of those models work fine alone in scene.
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
check this Error from earlier today. That's what windows app center gave me as message after 5-6 sec freeze while Octane was rendering and then aborting render. After that i had to close layout, photoshop and DWG viewer, they all "lost" openGL/image in programs.
- Octane_Crash_GPU.jpg (86.99 KiB) Viewed 8503 times
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
Hi !
Have you disable TDR ?
Or set a bigger delay timing ?
http://http.developer.nvidia.com/Nsight ... covery.htm
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
I don't found these variables for W10, are they the same ?
Reboot is must need for process !
And cheap primary card to !
Best regards.
_
Best regards.
_
I have it set for 10 seconds on my windows. What's your settings.stef wrote:Hi !
Best regards.
_
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
I disable TDR !
Others things may help, or not .. For rendering,
- Switch LW in bounding box ( cpu render )
- Update bios firmware, and PCI drivers
- PC power options to the max perf
- Optimise all instanced objects
- Good air flow in the office
- Leave monitor ON ..
- Last GTX drivers
Good luck !
_
I disable TDR !
- Last GTX drivers
Good luck !
_
Can you post screen-grab/settings of your registry how to disable it ? Thanksstef wrote:Hi,
I disable TDR !![]()
_
BTW this 719 is definitely Octane BUG/problem. By now I've tested this scene on 3 machines so far, different GPUs (Maxwel/Pascal/Kepler all in mix and all in separate) and i've even gone to octane 2.25 and they both "die" after some time of rendering with that CUDA 719 log/problem. I've even gone so far that i packed scene (1GB in total RAR) and sent it to another user (Thanks Oliver) and he run it on his Machine and it died after 20-30 minutes also.
So far tested on 3 PCs, 3 windows versions (win7, win8, win10) and 10 GPUs in total tested (TitanX, 2*780, 2*1080, 1*780Ti, 4*980Ti) and it always dies with that silly 719 LOG error message. Sometime after 2 minutes sometime even after 2 hours of rendering but it always fail.
Must be Octane BUG then.
P.S. I've even re-modeled geometry (it was crappy Sketchup export model full of N-gons and Non planars...) form scratch to make it QuadsTris only and no N-gons and tripled all non-planars and still same issue. I tried PT and PMC kernels, no difference.
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Skype - lewis3d
ICQ - 7128177
- LightwaveGuru
- Contact:
https://www.txcorp.com/images/docs/gpul ... codes.html
cudaErrorInvalidTextureBinding = 19, ///< Invalid texture binding
lwguru
lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
