max viewport black
crackfox
i am having a strange issue since day one with octane:
all of the object in the viewport are pitch black. if i add a light i have to crank the value to 10000 to have it light the scene.
working i a completely black scene is really a no go and the one of the reasons i stopped using octane.
this cant be, right can it?
ThaRaven
had the same problem.. was the scene scale in my case.. switched to generic units. now its bright with a setting of 2 or 3.. also i changed the environment collor to grey or something to see objects without lights..
Win 7 64 | Geforce GTX780 |Dual X5667 Xeon | 40GB | MAX 2016 |
crackfox
thanks raven i will play around with the units.
strange that viewport is completely dark no matter how high the light settings are.
cheers-
ThaRaven
also there is a bug atm when using a free Cam.. Renders ok in Octane Viewport but Black/White at Render times.
I also noticed that when changeing lights from Temperature to Color they become much brighter.. Hope it helps
crackfox
thanks for the heads up man.
appreciate it.
Return to “Autodesk 3Ds Max”
