[OCT 3.x] Minor & Major issues of OCTANE for 3ds Max
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
kcpr-raffaEl
Issues for OCTANE 3.03:
1. Crash when Normal bitmap has UV channel other than 1
2. All versions of OCTANE - sometimes picking map in Material Editor taking FOREVER - like 2-3 minutes of waiting until Map list appear - it's really annoying!
I'll add more if I spot something.
azen
Thanks for reporting.
The second bug in particular sounds quite extreme. If I am unable to duplicate the issue, I will come back to this post with further questions about your setup.
kcpr-raffaEl
Bumping up this topic.
Waiting foe Material/Map Browser is taking from 2 to 5 minutes (!!!).
This happens only once (bringing Browser first time) per 3ds Max session.
Can you investigate what is the reason?
Do other users experince the same issue?
kcpr-raffaEl
Guys from OTOY,
I'm getting REALLY frustrated and annoyed by the lack of your response.
My problem with Material Browser still persist, its related with number of materials in scene.
The bigger amount of materials the longer time I have to wait.
With 3 Combo Licenses of OCTANE I'm feeling really ignored.
Do you have any support here?
thekwen
Quite the same here.
Opening material editor can take many many times, and when having a multi subobject shader i just go make some coffee ...
Kwen
paride4331
Hi all,
in reference to the post:
viewtopic.php?f=80&t=57079&start=20#p293499
I do not know if this Envrironment slot material issue is related to the plugin version.
Could you tell me your gpu used and nvidia drivers?
Did you change GPU between 4:21 and 4:22?
kcpr-raffaEl
kcpr-raffaEl wrote: Picking map in Material Editor taking FOREVER - like 2-15 minutes of waiting until Map list appear - it's really annoying!
kcpr-raffaEl wrote:Bumping up this topic.
This problem is STILL not adressed.
Sometimes with larger amount of materials I have to wait 15 minutes (!!!!!) to Material Browser show up!
My setup (problem persists on all my three computers):
Intel Xeon 920 @ 3,6GHz
ASUS Rampage Extreme II Motherboard
24 GB of RAM
3x GTX 1070 Hybrid
Intel Core i7 960 @ 3,6GHz
ASUS P6T7 WS Supercomputer
24 GB of RAM
GTX 980Ti + 3 x GTX 780
Intel Core i5 Lynnfield @ 2,8 GHz
ASUS P7P55 WS Supercomputer
16 GB of RAM
4 x GTX 780
Please fix this issue, because it makes your software unusable for really serious work.
paride4331
Hi kcpr-raffaEl,
Do you have HDRIs and/or environment maps in your material editor? Are they on a local drive?
Did you try to "Enable Texture environment Preview" option?
kcpr-raffaEl
I'll check this and let you know!
kcpr-raffaEl
OK, here is what i managed to check:
- all images are on local drives
- there are HDRI images also
- problem raises when in Material Browser is open additional library with many materials
- as higher number of materials - the longer time of waiting is needed
But this issue doesn't show up all the times, I'm trying to specify the circumstances when it appears.
Return to “Bug Reports”
