OpenVDB sequence delay
Jackytalpalar
I need to start explosions at different times on the same animation and I want to use the same simulation several times with delays between them.
How can I tell an OpenVDB sequence to start at a determined frame?
Thanks.
juanjgon
You can add the $F token to support OpenVDB sequences (using files like volue_0001.vdb), but I am not sure if using this token you could add the delay you need to the sequence, because $F is going to use always the current frame number.
Let me think about a solution for this workflow.
Jackytalpalar
Thanks Juanjo!
3dcgmodeler
any ideas on this
I also want to do the same thing
Mike
ASUSTeK COMPUTER INC. ROG STRIX TRX40-E GAMING Rev 1.xx
1Ryzen Threadripper 3970X 32-Core - 3900 MHz (32 cores, 64 threads)
131072 MB DDR4 DIMM 2133 MHz (8 of 8 slots)
juanjgon
I am thinking about a solution for the next build, probably with other token to set the initial sequence frame.
juanjgon
For the next build, I've added a new parameter to set an offset for the current frame that is extracted from the $F token.
Return to “Lightwave 3D”
