Question about Daz Victoria 7 Node settings
Moderator: BK
morphious2013
Daz Victoria 7 has an SSS map with veins on it. But when Octane converts the maps, they do not show up in render. The SSS map is in the Transmission/Greyscale Node.
Tried changing values of all nodes, but nothing helps. Any ideas??? Thanks.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
The SSS generated from a map in the Transmission node is very subtle. I doubt you would detect veins from such a map in a render.
morphious2013
In daz, adjusting certain nodes causes the veins to show in render. Just not sure how that translates to octane nodes. What node should the map be placed? Or should views be on a different map type and which node? Thanks.
Hydra
You can experiment with geoshells;
viewtopic.php?f=44&t=54671
Let me know if you have any success.
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
Sorel
If you're just using the default conversion the plugin creates that is your first problem. I dun that diffuse/glossy mixture is not great for skin. I would try to work with specular/diffuse or specular/specular recipe.
Sorel
Here is a test using Lee 7. my setup is a specular/specular material. sss map goes in one node and the diffuse map in the other.
morphious2013
So, with Geoshell, I would apply the Victoria 7 SSS map with the veins to the Geoshell?
morphious2013
Sorel, I don't understand. The diffuse map is in the Diffuse node. The SSS map with the veins is in the Transmission node. How is Lee setup different? Screen shots maybe would help. Thanks.
Sorel
morphious2013 wrote:Sorel, I don't understand. The diffuse map is in the Diffuse node. The SSS map with the veins is in the Transmission node. How is Lee setup different? Screen shots maybe would help. Thanks.
As I stated in my previous post I used a mix material setup of specular/specular. I can upload my recipe when I'm not at work. It's actually a modified version the Tony sculptor R20 material from the live db so you can probably start experimenting from there.
morphious2013
I think I figured it out. Selected Torso in Materials TAB. Scrolled town to Specularity Node. Changed it from greyscale to RGB Image. It then disappeared sort of and reappeared/added Specularity under the Diffuse material Node. I then loaded the SSS map into that node, and the veins showed in render. Is that what you have done? Thanks.
Return to “DAZ Studio”
