Noise in glass object
- MichaelYpes
I am trying to create a glass object with little light emissions in the middle. The middle part of the glass seems to render great but the edges are very noisy. I have tried both pt and pmc which I have enclosed. The glass index is 1.1. Anyone know what settings to get a good glass render. Rawandrendered does them all the time and that is the effect I am trying to achieve. his is obviously the good one
it looks weird and don't think that's a noise as usual
- MichaelYpes
Do you think then that it might be the geometry of the shape? It is an icosa where I have extruded and then put a cloth over it to give it depth of 10cm (now 2cm in new file) and then hypernurbed it. I can provide source file if that helps?
- 134 Glass Ball.c4d.zip
- (193.04 KiB) Downloaded 177 times
Yes, weird
I have tried to reproduce a similar scene but it cleans fast: maybe something strange in the environment settings
ciao beppe
ciao beppe
- MichaelYpes
Thank you @bepeg4d
Your render looked sweet and was exactly what I was looking for. On close inspection I see that I gave the cloth nurbs a minus value and that is what was giving it the weird look. Changing it to a positive value made the render look more like glass.
On another note I like the model you did to as it was more spherical. Which type of sphere did you use and how many segments to get that look
Thanks mate.
Thanks mate.
I glad to hear that you have solved
your reference image is very inspiring, I have used an hexahedron sphere type with 6 segments
ciao beppe
ciao beppe
I got a similar problem, as well as high render time.
In time: anyone know why the shadow from the emission plane? I did try area light also, but I thought that emission would emitt both ways.
https://drive.google.com/file/d/0B3ne-5 ... sp=sharing (32s) and the viewport/live render: https://drive.google.com/file/d/0B3ne-5 ... sp=sharing
- MichaelYpes
Thanks for you're help @bepeg4d
Decided to change my model a bit but pleased with the outcome thanks to your help
Hi jeanco,jeanco wrote:I got a similar problem, as well as high render time.
no, the emission always goes in the polygon normal direction. You have to use at least a cube for having the emission in all the directions, and avoid intersections between emissive polygons and other geometry to avoid noise
ciao beppe
