How to hide Blackbody Emitter object in refraction?
R_Flash
Hi.
I know, Octane ObjectTag not helps to hide blackbody emitter mesh in refracted or reflected object (glass or water), but maybe somebody know any tricks to avoid this restrictions? Thanks.
Win7, i7 950, 12Gb RAM, GTX580
Use general visibility in object tag.
R_Flash
aoktar wrote:Use general visibility in object tag.
Decrease of "General Visibility" parameter in ObjectTag destroys BlackBody Emitter effect. :(
It's not destroying illumination effect. Which effect do you mean?
R_Flash
When I set GeneralVisibility paremeter closer to 0, highlights on glossy materials disappears and lighting becomes uniform.
Maybe I'm doing something wrong. Explain, please
GeneralVisibility = 1
GeneralVisibility = 0.01
Hi R_Flash,
nothing wrong from you, but this is expected if you cheat by hiding the visibility of the emission. As you can see, the general luminosity is not changed, but the image is completely different because glossy and specular materials have nothing to reflect or refract.
Have you already tried to reduce the reflectivity of the window's glass instead?
ciao beppe
R_Flash
bepeg4d wrote:Hi R_Flash,
ciao beppe
No, This I have`t tried, yet. ) I`ll try. Thanks.
