Straight Alpha broken in V3 ?
rojharris
I can't find an answer to this on the forum but is the alpha channel broken in V3?
If I render a straight/separate alpha (C4D save dialog) then tick 'alpha channel' in the kernel settings, making sure to NOT set 'pre-multiply alpha' in the cameraImager settings I should in theory get a beauty pass with a pixellated 'fringe' that then gets cut out by an anti-aliased alpha channel. This should result in no fringing at all on any bg when combined in AE.
However this is not happening. I'm getting horrible white fringes around all my objects?? In fact, the standard normal alpha looks better albeit with a very thin fringe. Anybody seeing this? Should not be happening. Where am I going wrong?
Nothing is broken because there is not any relationship between plugin and this parameter. And never has been like that. I think you should deactivate "KEEP ENVIRONMENT".
rojharris
Yeah, sorry, brain freeze! I remembered that just after I posted.. Its all working fine now.
