Image of OBJECT 'Painting' not working in Octane
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
rappet
Hi Paul,
WHen having an image assigned within the Object 'Painting'... it does not show in Octane.
Is that not possible and a known issue?
It seems ArchiCAD handels the image of the painting not as a material and therefor it is not shown?
I tried to morph the Object, but then the image is not shown in ArchiCAD either ;-(
hope there is a solution for this?
Let me know if you want me to send you a testfile.
greetz,
Edited:
With the tv object is works OK... (the TV object does show the image wehn making it a morph, so there is a big difference in Painting object and TV object)
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Check the Octane material for the picture - does it have the texturemap in the diffuse channel? If so, it might be a UV mapping issue.
rappet
Hi Paul,
The Painting Object does not have an image for the dffuse map.
(The TV object obviously does.)
greetz,
PS
I have PM -ed you the PLN testfile.. just in case
edited:
During testing I noticed that with both (GDL) Objects, in ArchiCAD you can assign differtn images to the painting/screen,
but when opened in OCtane all objects have the same material, and therefor the same image.
trying to figure out a solution, without having to make new 'paintings'... i.e. I can draw thin walls with texture.
but in the project I have to many paintings, and that will be too much work.
So I will try to find a solution for a few clicks :roll:
Hopefully this is an issue that can be fixed in future?
Edited2:
For the TV Object I have a solution by making the Objcts a Morph.. but that does regretfully not work for the Painting object
rappet
The painting object is also not exported correctly to Skectup or Cinema4D,
so this is outside Octane plugin.
I have reported this issue to the local helpdesk (Kubus = Dutch Archicad distributor/developer).
Thanks Jeroen.
Return to “Graphisoft ArchiCAD”
