Version 3.03.3-R1 (11.08.2016)
vi-ex
I can confirm the following problem in the windows version.
arleksey wrote:when i tried to open Octane Render 3.03.1 - R1 render settings (CTRL+B) i get this error, R17
3.02-R2 works well
Alex2002
I got the same issue,
open Octane Render 3.03.1 - R1 render settings, get error.
C4D version: R17.048
CPH_Pixels
aoktar wrote:I've updated links with 3.03.1-R1 version. Enjoy!
Hi aoktar
New user here - So maybe noob level ;-)
Did you update the mac version as well?
I have 3.03.1 standalone on master and slave, and that works.
But in C4D I get the same error with 3.3.1.
I've downloaded from the link in this post 3.03.1 macosx.
But the files doesn't end with R1 - Like the windows version does.
Any chance You can fix that?
Hi aoktar
Sorry i've fixed macos version. I did a mistake on links. I've had some trouble on hardware since a few days so caused some chaotic case on builds. I'm gonna fix also pc version in one hour.
Also there is a problem on 3.03.1 SDK about 'invert' parameter in mediums. I'll make new builds when fixed SDK come out.
Big sorry for troubles.
Alex2002 wrote:I get the same issue,
OSX? Can't see the problem on windows version.
CPH_Pixels
Thank you so much, that was quick ;-)
No need to be sorry - Without You, everyone would be stuck ;-)
Thanks again !!
I've fixed the links. But as i said that there is a problem on 3.03.1 SDK about 'invert' parameter in mediums. I'll make new builds when fixed SDK come out.
vi-ex wrote:I can confirm the following problem in the windows version.
3.02-R2 works well
I think this is first time that you run V3. It makes a copy of vprenderer3.res to vprenderer.res from c4doctane/res directory.
You can fix it by run the C4D as administrator or make it by your self. I think windows avoid to copy it when you have c4d in program files.
I'll change the system for next version.
Alex2002
Hi, aoktar
My systeam is WIN 10~
Live viewer render is ok, but can't open render setting.
Terryvfx
Still having issues with alpha pre-multiplication, it just doesn't want to come up as straight when you use the multipasses. :?
Return to “Releases”
