Regular bitmap usage completely broken..
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
daniel.reutersward
Hello,
Regular 3ds max bitmaps plugged in to the rgb image node is completely broken.
I have attached a image showing this (all the purple error everywhere).
If I copy the texture location and paste it in to the rgb image everything works as it should.
This scene worked perfectly with 2.x version.
/Daniel
HHbomb
same here with 3.02 4.6.
JimStar
Can't reproduce so far... Could you please give me the scene where it happens for you?
daniel.reutersward
JimStar wrote:Can't reproduce so far... Could you please give me the scene where it happens for you?
I´ve tried several old scenes with the same issue. I will try with a new scene and se how that works.
If that doesn´t work I will send over a scene to you.
How/where should I send it?
JimStar
No problems in my tests. So, just attach the archive with the scene here...
JimStar
I think I've found what may be the reason of these artifacts sometimes appearing. Will release the fix in a next version, just let me know please if you will still get this issue...
JimStar
You can try THIS VERSION.
daniel.reutersward
JimStar wrote:You can try THIS VERSION.
It seems to work now, thanks JimStar!
Return to “Bug Reports”
