OctaneRender® for Maya® 3.03.1 - 8.0 Win [ALPHA]
Sub forum for non-production plugin releases
k.a.schubert
cyrillweiss
Thanks for the error message!
Maya 2016 ext2 is Maya 2016.5, right?
The plugin should not work with that, since the 2016.5 SDK is not yet used,
so its correct, that the mll is not copied, since the 2016.5 Path is not included in the setup.
Would be next thing to do, using SDK 2016.5.
Any error message with Maya 2016, 2015, 2014?
Should not be the same behaviour.
gah5118
more information: not using .5 here to note. It's showing up in the plugin list.
tried it with both 2014 and 2016(not .5) with the same results and no chance for a message. just crashes immediately. Checked the log and no messages in there either. I also watched the output window in case something shows up.
the only information I can grab that is probably not useful is in the mel echo " $ignoreUpdateCallback = true;" is the only thing that pops up after clicking the plugin.
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
k.a.schubert
Refreshed the downloads with the fixed version.
Did not include tbb.dll (for OpenVDB) in the setup, so mayas own was used, which made octane crash on startup.
Was just lucky on my dev machine to be using the correct dll.
ptunstall
WHAMMY!!! Working great in 2016!!! THANKS MAN, TOTAL CHAMP STATUS!!
johan_D
Thanks kai,
But that don't work with V2 licence? we don't have time to test like other plugins before buying the v3
Best
limeforce
Yay! Up & rendering! Hope I can soon dig in properly and give feedback :)
Jolbertoquini
Hi Kai,
What we do when the manage button is lock and give us a error of activation? standalone all fine only Maya give this problems??
I have Maya2015/also 2014
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
ivankio
Nice. Dropping a reference of what seems to be the minimum to start a render and how to plug the camera. May be obvious to people familiar to Octane Standalone, but not all Maya users.
@k.a.schubert, I know this alpha is just the barebone and you probably have a better idea to quick start renderings.
But before it's too late, I hope you didn't miss my suggestions to make the setup accessible through the familiar Render Settings window:
viewtopic.php?f=28&t=53709&start=80#p279066
Also, please do not overwrite 2.0 (unless you plan to make old scenes compatible :mrgreen: ).
"Scale (1 unit = X meter)" is messing with the position of the camera (I guess the CameraTransformConverter isn't factoring it).
GTX 1080 8gb, GTX 970 4gb, I5 4590, Z97-E, 32gb RAM, Win 10 64bits, Octane for Maya
limeforce
ivankio wrote:Nice. Dropping a reference of what seems to be the minimum to start a render and how to plug the camera. May be obvious to people familiar to Octane Standalone, but not all Maya users.
Thanks for the pic, made me realize I need an empty Geometry Group connected to the Render Target to see my scene, was wondering why I'm only seeing my Daylight Environment.
itsallgoode9
ivankio wrote: Also, please do not overwrite 2.0 (unless you plan to make old scenes compatible :mrgreen: ).
Like, does nothing in the hypershade from 2.0 convert over...materials camera settings etc? will everything need to be manually rebuilt in 3.0? :oops:
Return to “Testing Releases (Non-Production)”
