Hi Paul,
maybe I am doing something wrong but very often the Renders don't match with exact Safe Frame that is set in the Rhino options.
The Rhino resolution is set in the same dimensions as the Octane Render target but the renders don't match 100 %.
What wout be the correct workflow???
Thank you
Nando
Render View not matching with Save Frame
Nando - can you post a screenshot and a sample scene showing this problem pls?
I will try to reproduce this, because I can not hand over the scene...
Will get back to you soon.
Thank you
Thank you
HI Paul,
this is an example of the viewport not matching Rhino's save frame.
The viewport should end with the corners of the cubes.
How can I fix this?
Kind Regards
How can I fix this?
Kind Regards
- RenderNotMatchingViewport.zip
- (28.9 KiB) Downloaded 341 times
Hi Paul,
is there a solution for this?
We are having trouble here.
When we rerender shots they are not matching perfectly.
Ciao
Nando
Ciao
Nando
Yes my render views changes as well when I switch monitors. Is there a proper way to keep saved views locked or at a default resolution
Its been a problem everytime I switch pc on the same file.
Still not too sure on this work flow
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
I put a fix for this in 3.0.22.66. Is this still an issue in the latest release? If so - can you post a sample Rhino file which shows the problem pls.
