hello team octane render team, i have a problem with to see the objects forest into octane render i have in use 5.0.5 forest pack versi{on i been talked with the administrador of the itoosoft and this was your words:
add image to see answer:
hope you can understand this problem into octane with forest or forest with octane
thank you team octane render
not see forest into 3ds max view
C. RAM Capacity (i.e. 6 GB)
still i can't see forest into viewport octane when i active movable proxy, is a problema becouse still time when i insert a forest and chanche the properties i need do click in refresh to appear the forest and that is a headache
exist another way to do more interactive forest with octane or is the only way ?
thank you for answer octanerender team
- hojas.zip
- not see forest still
- (5.32 MiB) Downloaded 156 times
