Is it possible to map animation using image Sequence Map?
It seems that does not apply to the animation trying to Sequence Image.
image Sequence mapping animation?
It rotted the Octane Mix Texture or Octane Multiply Texture Creating images Sequence is not working.
I want to create multiple image sequences by using the Mix or multiply does not work.
Will not this way?
Will not this way?
juanjgon wrote:If you load an image as a sequence in the LightWave image editor, it should work in Octane without problems, but due to some limitations in the LightWave SDK, some controls, like the start frame, pre behavior, etc. can not work.
Hello Juanjio
has this been fixed?
Im exporting some normal map from realwave to displace an ocean, but i can't get
the sequence to work... I apply a texture image node, put it in the diplacement an then to the material....
displacemnt work but not the animation...
Im using version 2.2
i thought that but it doesen't seems to work...
Will do some other test and in case submite a sample scene ok?
yes...
Im doing a test now I think there was a problem in the first image generate by realflow numbered 00000
the image was flat and image editor shows it fully black
Deleted that one it seems to work im rendering it now 15 frames as a test.
The nice thing is that realwave displacement are tileble so im displacing a scquare and instancing an array of them and you don't see in octane any
connection.
Will let you know if it works
thanks
connection.
thanks
it works...
does the loop option work of image sequences or not?
