Octane 3 material ERRORS. Urgent help if possible
- L_Sprangers
Hey everyone. Just out of the blue today I started experiencing problems with Octane 3's material system. The material icons started turning all glitchy with bars of color and it started resulting in automatic render failures. I noticed it started being triggered upon using a Mix material. Shutting down and rebooting was no help. Is anyone else experiencing this problem? Octane is basically unusable now and I'm right in the middle of a project with a deadline coming up. So I need a fix as soon as possible
I've never seen that. Did you tried to open your scene in standalone? Or did you tried to edit this material in standalone? Maybe it could help to identify the source of this problem.
Just an idea...
Just an idea...
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
- L_Sprangers
Thanks for the quick reply. I'll give it a try. I notice it's been occurring also when I load materials from the Live Database
Pls check octane log! I suppose that's a driver issue.
- cmittenaere
I Had the same problem. Just save and reboot cinema 4d... Never that with v2
- L_Sprangers
But it never happened in V2. When i reboot C4D it's fine for a while, but then sometimes I just click on a texture and the icon turns to these pixelated colors and I have to reboot again.aoktar wrote:Pls check octane log! I suppose that's a driver issue.
Hi L_Sprangers,
does this happen only with v2 scene opened in v3?
If yes, could you try to replace all the octane object tags?
ciao beppe
ciao beppe
- FlowFireGames
I also had this today when using a octane image texture. I changed the float sliders and the bug occured. Later with a similar image texture, all my materials were glitched suddenly. Thank god did restarting fix the issue.
