Yes, probably. Try it to see how it works.
texture layering node or at least an Add node?
Cool! It is a good workaround to store point/vertex attributes data until we have the proper attributes support. You can use the three available UV maps in Octane to store up to two float values in each one, and later use the UVW projection node to get these values for shading.
in case someone needs an explanation, I hope the attached files are helpful.
Yaniv
Yaniv
- vertex_color_to_uvs.rar
- (166.48 KiB) Downloaded 267 times
