Cannot see object in rendered image
The OCS file define the octane node tree, but you still need the OBJ file for the kitchen geometry.bkjernis wrote:As well where is the preview configuration in Octane 3 standalone? Thanks, Brent
As I can't see the geometry, only guessing here:
when you open the scene, you are inside the kitchen but there's no light inside it so you only see a black picture ?
To let environment light go into the kitchen, you have to assign to windows, a transparent material or a specular material with transmission (or delete windows geometry).
Pascal ANDRE
Here is the obj. file Calus. Does that help you? Could you post an example of how this should be set up? I have Octane 2 as well but have not used it so I am new to all this. Thanks
This is the kitchen. It is designed and rendered in chief architect. I cannot remember if I converted it to obj. with rhino3d or blender3d.I hope this helps. Thanks
So that was not a light problem, I found your kitchen!
it's visible in the scene but very well hidden
here is the scene with camera seeing the house :
as you can see the house has a 90 degre rotation, and is really far from the scene center.
This is because blender use a Z up axis while Octane use Y up axis ...
You can use the "placement" node to put the house in the right rotation and position...
(Also better to put your camera to a panoramic camera while doing this)
Pascal ANDRE
