Version 3.00 - R1.1 (25.05.2016)
jayroth
I just installed 3.0R1.1, and all seems well, except for the fact that the Live View will no longer allow for camera orbits with alt-left-mouse. The view will properly behave until I release the mouse button, at which time the view will snap to the state of view as when the file loaded into Cinema. Pan and Zoom seems fine, this is limited just to orbit. I looked for a setting to control this, but I cannot find one (and this would differ from previous versions regardless). Is this a known issue?
Cinema R17.046 running on Win64 8.1
Update: Light Colors are not updating either. I think I may have a bad install, though I did follow the directions... I will investigate further.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
jayroth
OK, I found this camera issue. This is an imported LWS file, and apparently there were keyframes on the camera. As such, the Octane viewer jumping back would likely correct in this case.
Yan
aoktar wrote:Yan,
can you send me a sample scene?
It's a commercial project so I cannot post it online. Sorry.
Somehow I have fixed the problems by copying everything into a new document.
I don't know why, but everything seems to work now.
I'll get back if I will get new errors.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
Yan wrote:
aoktar wrote:Yan,
How about to delete parts but still seeing errors. I'll may not help to requests when any scenes are not attached. Sorry for that but it's just 10x time loose on issue to understand what's that. And at the end it's mostly a user error.
valters
Can somebody why my Grid Mapping have only VelocitiesZ and no other?
VDB made wrong? - Vdb provided by my friend using FumeFX
Any suggestion or link to help?
Thank you
dinf
valters wrote:VDB made wrong? - Vdb provided by my friend using FumeFX
Could be a possibility. Mind posting me one file?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
valters
Thanks for trying to help :)
p.s. from all what I read guys got VDBs from Houdini most. Looks time to learn it :/
mv_def_v001_0065.zip
(5.66 MiB) Downloaded 248 times
dinf
valters wrote:from all what I read guys got VDBs from Houdini most. Looks time to learn it :/
Thats what I use to look after it.
There are 10 VDBs in, VelocitiesZ is the last one. But they all seem to have 3 values, even the x, y and z volumes. Don't knwo why Octane takes the last one of all things, but 3 values in every volume seems to be a bit much.
Btw: Is it intention that all the volumes of frame 0065 have square or rectangle shapes?
Hi guys,
Here is something to share with you. Making any sense?
milanm
aoktar wrote:Hi guys,
Wow! :o
Thank you Ahmet!
You. Are. Amazing.
Regrads
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
Return to “Releases”
