Was anyone able to create fire, smoke, clouds?
coilbook
Hi I wonder if anyone was able to create fire, smoke, clouds using Octane for 3ds max?
boris
did some tests.
you can create your own vdb files using fumefx or houdini if you have access to it.
or download sample vdbs from http://www.openvdb.org/download/
create a octane volume and link the vdb, place a "volume medium" an play with the values in material editor.. the "volume step length" is one important value.
PS: renderings took a minute or two. so speed is quite good i think.
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
coilbook
boris wrote:did some tests.
Wow! Nice thank you
ThaRaven
Fire and Smoke seems to work. Fire emission creates noise that takes allot of time to clean up
Win 7 64 | Geforce GTX780 |Dual X5667 Xeon | 40GB | MAX 2016 |
ThaRaven wrote:Fire and Smoke seems to work. Fire emission creates noise that takes allot of time to clean up
use low values in gi_clamp ;)
ThaRaven
will try that. not simming anything larger at the moment till i manage to get rid of this.
Edit:
Also matching the Octane Vollume to the Original Grid is a pain .. Point cloud display would be nice to do this ;)
boris
ThaRaven wrote: Also matching the Octane Vollume to the Original Grid is a pain .. Point cloud display would be nice to do this ;)
+1
coilbook
Nice I was worried about noise too. Is this Diffuse or AO. I hope Octane will implement that antinoise program they were talking about
coilbook
By the way has anyone tried to use Octane Cloud Service. IS it pricey ? is it fast?
Thank you
ThaRaven
it was PT. could not get the Fire to scatter through smoke with DL
Return to “Autodesk 3Ds Max”
