Noise threshold
DonFarese
Version 3 is great improvement, I think Octane can really improve much further in speed if it had a noise threshold setting, this way it isn't unnecessarily sampling areas that don't need cleanup and focuses on the areas that do and renders way faster. Vray has this and now so does Corona and the speed up in render from it is pretty huge. Noise threshold also allows you to have a consistent render through animation and also lets you calculate your render better.
Win 8.1 64 | AMD Firepro W7000 + Geforce GTX Titan X | i7 3930k | 32GB
calus
logically noise threshold feature will come with "adaptive rendering" which should be a 3.1 feature.
Pascal ANDRE
DonFarese
calus wrote:logically noise threshold feature will come with "adaptive rendering" which should be a 3.1 feature.
I'm glad you wrote than, I was suppose to write adaptive rendering too. Doing to many things at once, brain fart. Yes those two things would be huge, how do you know they are coming in 3.1? is there a public road map i'm not aware of?
calus
Well Abstrax explaind here it will be easy to add :
viewtopic.php?f=9&t=53383&hilit=adaptiv ... ng#p269534
and here Goldorak said it will be for 3.1:
viewtopic.php?f=9&t=53383&hilit=adaptiv ... 20#p270435
Pascal ANDRE
DonFarese
Wow this sounds awesome!
RobSteady
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
DonFarese
I'm not completely sold on Coronas Adaptive sampling, unlike where Vrays makes it much faster to render, Coronas actually makes it slower in most all cases. Also I've tried denoise and with high detailed objects like trees or grass blades, it washes out a lot of the detail. I'm sure it will get better over time but for right now.......
