Smooth & Easy Camera Animation for OR Standalone, ORC v1.21
roeland
This version should work with versions 2.25 and 3.00 alpha 10:
OlReadyCam_3.0.zip
(50.35 KiB) Downloaded 687 times
I had a look, and there are 2 breaking changes in the Octane API:
  • The imageSaveType enum moved to another module
  • The shutter speed settings moved to a node on the render target
The script also no longer overwrites ORBX files.
Roeland
smicha
Thank you!
ff7darkcloud
I just saw this, you just made my day! And it is only 12:16 am! Thanks!
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
glimpse
thanks! =)
Cosoli
roeland wrote:This version should work with versions 2.25 and 3.00 alpha 10:
But It doesn't work with Octane Render 3.0 for me..... :shock:
When i used "OI Ready Cam", it showed that
Wrong data type for key
Could anyone help me?
Hi Cosoli,
you are right, it works till v3 beta 1 and then it has stopped to work with that error message. Could you use v3 beta 1 while roeland find the time to have a look at the script to fix it?
ciao beppe
roeland
Yes the problem is the line keyframe.screenItem[b][[/b]i].slider.value = keyframe.item[b][[/b]ix]. I added more validation in the Lua API in a couple of places, to avoid such code failing silently if there's something wrong. The upshot is, if a value is set which is not the right type, or if you try to set nil then it will raise an error.
You can replace the affected function with the code below
function keyframe:setDefaultSliderValues()
    for i=1, cameraFile.totalFrames do
        keyframe.item[i] = keyframe.defaultSliderValue
    end
    local ix = keyframe.index
    for i=1, keyframe.screenLimit-1 do
        if keyframe.item[ix] then
            keyframe.screenItem[i].slider.value = keyframe.item[ix]
        end
        ix = ix+1
    end
end
Roeland
OlReadyCam_3.0.zip
(50.36 KiB) Downloaded 1390 times
Cosoli
THANKS!!! :D
ff7darkcloud
Hello Roeland and Bepeg!! , I have been using 3.06 TEST 3 for commercial work now, and it has been great. The Adaptive sampling works awesome.
But looks like it this LUA script got broken. If you could fix it yet again, would be greatly appreciated!.
I attach screen with error.
Error trying to use.
Notiusweb
This is the part the error is complaining about
\orcbin\widget.lua
line 265 (self.bar = octane.gui.create), argument #3
 progressBar = function(self, argv)
            type   = octane.gui.componentType.PROGRESS_BAR,
            text   = argv.text or "",
            width  = argv.width or 400,
            height = argv.height or 25,
            x      = argv.x or 0,
            y      = argv.y or 0
        return self
    end,
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Return to “Lua Scripting”
