Dirt -> Texture Emission(SOLVED)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ratata
Hello,
I just noticed Dirt doesn't work (gets ignored) with Texture Emission in Alpha 10.1, it works in 2.25 R3
Also attached the file.
oct3_dirt_test_01.zip
(61.52 KiB) Downloaded 324 times
http://www.twitter.com/sandidolsak
6850k|64gb|4 x GTX980ti
twistedpoly
can confirm it doesn't work in v3 beta 2.1 too
i7-5930k, 64gb of ram, 3x980Ti + 2xGTX 780Ti
http://twistedpoly.com/
Hi guys,
when you use a texture with emission, is always a good idea to use the same texture also in the diffuse pin ;)
In this particular case the Diffuse channel was even disabled.
ciao beppe
ratata
Hey, thanks for the feedback.
I tried to make the simplest example possible, that's why diffuse is disabled. The shader I was debugging is quite more complex then this, but now you showed me how to work around the problem. Btw this works just fine in V2...
So it is clear that Dirt node gets ignored somehow in the execution and you need to force it by linking it to diffuse, since I don't need any AO in diffuse this seems a workaround that will do it:
Not pretty but it works, thanks again.
Cheers,
Sandi
This is not belong to plugins. Please post on standalone forum. My advice is to first check on standalone for renderer based problems when you find.
Return to “Bug Reports”
