Version 3.00 - R1.1 (25.05.2016)
Can someone be free to test this version before release? Changes are listed below. Thanks.
https://render.otoy.com/customerdownloa ... .1-win.zip
Changes of V3-b2.1
- New type parameter on volume object for allowing mode switch.
- Fix on PV and background alpha
- Fix on missed "invert absorption" on medium nodes
- Fix on rendershader function for C4D shaders
- Fix: Background object renderings
Yambo
Hi Ahmet,
Looks like the background issue and the invert absorption are fixed on this last version.
But there is a another issue i found today, regarding the the "matte" option inside the shader - scene file attached, i will explain:
This is a project i started with the prevoiuse version and it worked properly, right now when the "matte" option inside the diffuse material is on - there are some black noise weird stuff going on in the live viewer. Instead of just behave as a shadow catcher.
Thanks.
matte_issue.rar
(367.45 KiB) Downloaded 560 times
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo wrote:Hi Ahmet,
Thanks.
Yambo
got you, on previous versions it behave differently.
What does the "Disable partial alpha" is doing?
https://yambo.me
Yambo wrote:got you, on previous versions it behave differently.
Simply don't select it. It's for removing thin edge effect on mattes.
rwalker
OSX download is labeled b2.1 but the download is still b2.0, right?
rwalker wrote:OSX download is labeled b2.1 but the download is still b2.0, right?
Sorry, i though that i've updated. Fixed now. Thanks for notice.
eyeonestudio
OctaneDayLight : Fog On/Off - Wired in LV
(My Octane Setting>Env is Black)
1. Add Some Object.
2. Add OctaneLight
3. Add OctaneDayLight (Set Power 0, Set Fog)
Open LiveViewer.
Test On/Off OctaneDayLight . When Off the OctaneDayLight, background color change to white. :(
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Weezer
Hi Ahmet. Can I ask: in the release of Version 3, has OTOY added multithreaded OSX object conversion? One of the biggest bottlenecks with Octane on C4D and OS X is the time it takes to convert mesh data for rendering.
fatfreemedia
Has anyone else noticed a big difference in noise between v2 and the latest v3? also the scene appears to be rendering at approximately 0.9 alpha rather than fully opaque.
Win10 64bit | 3 * GTX970 | i7 5930k | 32GB
Win10 64bit | 2 * GTX970 | i7 4790k | 16GB
Win10 64bit | 3 * GTX980 | i7 5930k | 32GB
Win10 64bit | 3 * GTX980 | i7 5930k | 48GB
Win10 64bit | 3 * GTX1070 | i7 6850k | 64GB
Return to “Releases”
