Pb with instances, mem and triangulation
- BorderLine
Attached exactly same scene close/re-open Layout. All instances are goods
- octane_OK1.log
- (651.16 KiB) Downloaded 139 times
Weird, it is like in the scene that doesn't render the instances, the LW11 instances rendering option were disabled in the render target root node options panel, or if the instance objects were disabled in the scene editor.
So this is the same scene, right? Without touch anything. Is it the same scene that I have here?
- BorderLine
Yes exactly the same scene for doing test.
But there are a few changes from yours.
Do you want i prepare package and send to you ?
- BorderLine
I hope this is not a hardware problem. My station is brand new!
- BorderLine
Think i'm going to reinstall LW for a clean installation.
- BorderLine
JuanJo,
I think I've found. I selected Out of Core and I indicated 12GB of RAM (because I have 64 GB) to see if my textures are read.
Since I deselected Out of Core, I'm not able to reproduce the problem instances.
I am a little ashamed !
Could be a memory problem, but I don't think so without some kind of CUDA error in the log, and anyway it is weird, because the out of core feature has nothing to do with instancing.
I have your scene here. I will try to reproduce the problem.
