where are my textures
s7r83dg3
I have played around a lil bit with this plugin and was able to export a simple animation, ok.
I halt the render, to add my textures. But everytime octane restarts it loses all the
textures/shaders etc...huh?
i792012GBGTS2501GB
s7r83dg3
okok :) so first i will export as obj and make an ocs and then use this in the plugin i guess ..
but now i get 'meshnode in project not usable' ...
i792012GBGTS2501GB
Proupin
plugin wha? what plugin? can you specify?
This issue "unusable object" search for it, but basically, when you add the mesh do it in the "Unnamed Project" tab of the Graph editor, NOT the "Preview Configuration" Tab. I think that if you do that it should all be good.
EDIT: here is the post - http://www.refractivesoftware.com/forum ... 950#p23950
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
s7r83dg3
Proupin wrote:plugin wha? what plugin? can you specify?
No, hte mesh is in its correct position. all files have the same name. no spaces, no äüöß ... doesn't work ... I'm using sp5r2 currently...
(btw isn't it ridiculous 5 service packs+r2 ;-) i know i know ,wrong forum...whatever))
i792012GBGTS2501GB
Proupin
hm... I think it would be best if you opened a new thread where you specify this problem you are having, preferably in a way that RS team can reproduce.
Are you using the latest Octane version and plugin?
Return to “Foundry Modo”
