Version 3.00 - Alpha10.1 (30.04.2016)
Weezer
I've been using Alpha6.3 and it's great, but I have a scene with volumetric fog (light beams from a sunlit window) that looks fine in the LV, but now won't render the picture viewer (image is fine, just no volumetrics). Any ideas why? I've been doing large renders of other scenes and it's been fine up until now...
Hi Weezer,
weird, could you share a simple scene that doesn't work for you?
ciao beppe
Weezer
It's really weird. I tested it on a box with hole in and it rendered just fine. I'm debugging it now. I think it's because it was built with version 2.x, and there's some sort of conflict somewhere... but it's really annoying!
[EDIT] Okay, it's working now with fog medium added via the DayLight tag. I'll see if I can get the Volume object working again...
martincarlson wrote: Sorry for behaving like a retard Aoktar. But, do you mean I have to save the document before I drag it to the LocalDB? Or do you mean the new document I import material to has to be saved first?
It's about importing. Because unsaved document has not path to be known where we should save this extracted images.
virtualzapp
Hi Ahmet,
I was playing with the baking texture feature with your example which is working great. The main issue I have encountered is when the texture is an image sequence to be baked on a geometry, the projection has to be set manually. I think camera projection is working as the same in 2.25 version, right?
Something really super great would be to have something like c4d camera projection for further precision and easy to set up.
Anyway I know you are super busy, and you are doing fantastic job for the c4d plugin integration but one day this feature would be a killer one ;o)
Cheers
Regis
VFX compositor / CG generalist
Mac Pro 12C 2.93GHz, 64gb ram, 1xGTX Titan X, 4xGTX Titans in Cubix
miohn
Hi Ahmet,
could we please get "render region" working again for V3 Alpha?
thanks
Mike
miohn wrote:Hi Ahmet,
thanks
Mike
Ok;)
luminouspowerhouse
Dear Akhmet,
Version 3.00 - Alpha 6.3 doesn't see my Titan 980 Ti, please see screenshot attached.
Using Mac Pro 5,1 OSX 10.11.4, nVidia driver 346.03.06f01
When I roll out back to 2.25, it's all working ok and Octane sees the card.
Any suggestions to troubleshoot?
Thank you!
CUDA requirements
Due to a CUDA compiler bug we had switch to CUDA 7.5, which means on Windows and Linux you may need to update your NVIDIA graphics driver to a current version which supports at least CUDA 7.5. On Mac OSX you may have to update the CUDA driver for Mac to a current version supporting at least CUDA 7.5.
miohn
Hi Ahmet,
thanks for Alpha10 but I suddenly need to activate when I try to start C4D
and none of my account serials do work.
thanks
Mike
Return to “Releases”
