OctaneRender 2 for Modo [OBSOLETE]
v1adut
Hi Paul,
Is it possible to insert 2 buttons as standard in the modo-octane plugin for octane.saveAnimation and octane.createUDIM ? These commands seems very useful yet they are not in the ui.|
Cheers,
Vlad
There are more new buttons on the way - so perhaps raise this again in a month once you see the next commands. In the meantime, you can add buttons for these commands yourself.
v1adut
I know Paul, but since this is a 2 release a month, it is not fun loose my configs in octane render, and ui I setup.
You can remember some of your settings between Modo901.CFG deletes with https://docs.otoy.com/Modo/?page_id=1091. It is necessary to delete your Modo*.CFG file in order to pick up some of the new plugin features from time to time.
The OSX Modo901/10 plugin version installer has been updated due to a problem with the previous installer version.
I have refreshed the STABLE installer downloads at the top of this thread to release 2.25.0.106 (the next TEST build). Pls see the TEST thread for release notes.
Return to “Foundry Modo”
