OctaneRender 2 for Modo [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Modo - STABLE RELEASE.
Modo Version
The plugin runs on Modo801, Modo901, Modo902 and Modo10.0v1 on 64bit Window Vista, 7, 8 or 10, OSX Mavericks, Yosemite, El Capitan, and Linux
Nvidia Driver Version
Windows/Linux : Nvidia drivers 344.x or later. Recommend 358.50.
OSX : CUDA Driver Version: 6.5 or later
Network Rendering
For Network Rendering, you must use the Octane slave release 2.25 available available from the Commercial Product News & Releases subforum.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8, Linux distro, OSX version, etc)
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Modo version and SR number
- OctaneRender for Modo version (ie. 2.0.10.16)
- List what other plugins you have installed for Modo
- The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Known Issues
For more information...
- Check the specific Octane 2.0 features in this plugin http://render.otoy.com/manuals/Modo/?page_id=977
- Check the details for running the plugin on Modo801 at http://render.otoy.com/manuals/Modo/?page_id=959
- Read the on-line manual
- Watch the "Getting Started" video http://vimeo.com/87048593
- Watch the "OctaneRender for Modo - Octane 2.20 & 2.21 updated features" video https://vimeo.com/119302514
- Watch the "Using Multiple UV Maps in OctaneRender for Modo" video https://www.youtube.com/watch?v=rvuFI3okFwA
- Watch the "Using Modo Material properties in Octane Overrides" video https://www.youtube.com/watch?v=fN9H_x_pDpQ
- Watch the "OctaneRender for Modo UDIM Support" video https://www.youtube.com/watch?v=8P7FGElafRA
- Read the FAQ
- Read the Troubleshooting guide
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
Windows
- OctaneRender for Modo 2.25.0.106 (Modo801)
- OctaneRender for Modo 2.25.0.106 (Modo901, Modo902 & Modo10.0)
OSX
- OctaneRender for Modo 2.25.0.107 (Modo801)
- OctaneRender for Modo 2.25.0.107 (Modo901, Modo902 & Modo10.0)
Linux
The previous version can be downloaded from:
Windows
- OctaneRender for Modo 2.25.0.99 (Modo701 & Modo801)
- OctaneRender for Modo 2.25.0.99 (Modo 901, Modo902 & Modo10.0)
OSX
- OctaneRender for Modo 2.25.0.100 (Modo801)
- OctaneRender for Modo 2.25.0.105 (Modo 901, Modo902 & Modo10.0)
Linux
- OctaneRender for Modo 2.25.0.99 (Modo801)
I have refreshed the installer at the top of this thread with:
2.0.10.16
- Compiled against Octane 2.0.10
- Fixed splash screen graphic
Tharso
Thank you Paul Kinnane !! You are very fast ;)
cuffi
Hi Paul,
I have a problem getting the new plugin to work with MODO 801 SP1. I got the following error:
Started logging on 13.06.14 18:24:18
OctaneRender version 2.00.0009 beta (2000009)
CUDA error 999 on device -1: An unknown internal error occurred.
    -> Failed to initialise CUDA driver API
All is working fine in 701 SP5 and Octane standalone 2.0.10
René
Win 7 Ultimate 64 Bit | GTX780 Ti | GTX 560 TI | Driver Version 337.88 | Intel Core i7 3930K 6x 3,2 GHz | 32 GB RAM
Web: http://www.mentalarts.com
[url]I have a problem getting the new plugin to work with MODO 801 SP1. I got the following error:[/url]That is showing you are running the plugin built against Octane 2.0.9. Can you pls try the 2.0.10 version at the top of this thread? Also, pls make sure you don't have Modo running when you update the plugin.
cuffi
face_off wrote:
cuffi wrote:I have a problem getting the new plugin to work with MODO 801 SP1. I got the following error:
Hi Paul,
Same with the new plugin 2.0.10.16 and Octane 2.10...I deleted the plugin folder and my MODO 801 config. MODO was off while I installed the new plugin...
Started logging on 14.06.14 11:15:20
OctaneRender version 2.00 (2000010)
701 SP5 and Octane standalone 2.10 are working still fine...
René
René - are Modo701 and Modo801 installed on the same PC? If so, they are both using the same installation of the plugin, so I am baffled how 801 could give an error whereas 701 does not.
cuffi
face_off wrote:René - are Modo701 and Modo801 installed on the same PC? If so, they are both using the same installation of the plugin, so I am baffled how 801 could give an error whereas 701 does not.
Yes they're running on the same PC side by side. That's why I am baffled too... :shock:
cuffi
Hi Paul,
I figured out the problem. I had installed a trial version of the new Power Translators plugin. After deinstallation of the Power Translators Plugin the Octane for MODO plugin is running fine again...It seems the plugins are interfering...kind of. :cry:
René
connartist
Great work! The only thing I've come across so far is that animating the Focal Depth for the camera in Octane Settings doesn't render out to an animated sequence, it just stays with what is set for the first keyframe. I noticed that I had to turn on "Load all frames into Octane" to get it to render out an animated camera move, and I couldn't remember if that was true before. But that still didn't fix the focal depth issue, even though you could see it changing when scrubbing the timeline. I even checked "Reload Materials Each Frame" hoping it would force it to recalculate but it didn't.
GTX 780 / Plugin version 2_0_10_16
Thanks!
Return to “Foundry Modo”
