OctaneRender for Rhino 3.03.2 [OBSOLETE]
neiwei845458454
face_off wrote:
when I update to the octanerender for rhino v2.24 to v3.x released, how much should I pay for this? or I only need pay for v3.x stand-alone released and I dont pay for plugins of rhino.
How about this?
I don't know Alxen. I'm sure Otoy will make an announcement regarding this shortly.
OK,Thank you.
Could OctaneRender may support the highest memory in the Multiple graphics cards? Now It supports the smallest graphic memory in the Multiple graphics cards.
My guess is that this would not be possible, however you would me to put this question to the Otoy team in the Octane Standalone thread to find out for sure.
neiwei845458454
OK,Thank you.
OK,Thank you.
Sorry for my typo - that should have read "My guess is that this would not be possible, however you would NEED to put this question to the Otoy team in the Octane Standalone thread to find out for sure."
I have refreshed the installer at the top of this thread with:
3.0.6.63
- Fixed error when the Hide and the Scale/Rot From Block Instance checkboxes are not being saved for proxy objects
- Changed OctaneChangePinValue command so the pin to be changed can be embedded in another pin, using the ':' separator. For example "OctaneChangePinValue camera:aperture 5", or "OctaneChangePinValue environment:texture:gamma 1", or "OctaneChangePinValue camera:fstop 3". See https://docs.otoy.com/Rhino/?page_id=711 for details.
- Added OctaneAutoAssignBakingGroups command which will assign a different baking group to every geometry item in the scene which has Live Update enabled. See https://docs.otoy.com/Rhino/?page_id=711 for details.
- Fixed bug where unticking Live Update would disable live updating of all geometry items
neiwei845458454
face_off wrote:I have refreshed the installer at the top of this thread with:
3.0.6.63
Hi Paul,
Thank you for your help. I see the OctaneChangePinValue command was improved. Thanks,I love this. And does this OctaneChangePinValue command suppper to OctaneRender for Rhino 2.24.2.56? I need to use this version.
I found one problem. Can you make a slider button for the hdri texture environment rotation by the Z-axis rotation angle? Just like a quickly tool likes Scale Textures slider button.
Does it possible?
Best Regards,
alxen
Done - pls see the STABLE release thread.
You can already do this by opening the Environment->Texture->Projection->Sphere Transformation node and moving the Y Rotation slider.
neiwei845458454
OK, Thank you.
Hi Paul,
I also need the OctaneScript command to support for this, like this:
I need to set it every time. I hope one script command for solve this.
Thanks for your help.
Alxen
Ah yes, sorry, I will put that in the next release.
neiwei845458454
Very Good! Thank you Paul. :D
Return to “Rhinoceros 3D”
