Assembly input type for normal map
adamnerva
What is the best way to create an assembly input for a normal map? I have not had much luck with this. The normal map is noodled into multiple materials within the assembly. Thanks.
Not sure I fully understand your question, but does the video below answer your question?
adamnerva
Thanks for the video Paul. I have managed to get this far. I guess 2 main questions remain. Do I always use a float input for everything? And how do I create a filename node? I've seen your are doing this, but I have not figured it out. Is that created simply by dragging an image from the clips viewer into the graph? Thanks!
Edit. OK, so yeah, dragging an image from the clips browser creates the filename node. Cool. So all that remains is the question about whether I should use float for all assembly inputs. Thanks.
Yes, all Octane node connections in the Schematic are "float" types.
adamnerva
Got it. Thanks a lot, Paul. You have been very helpful. I appreciate it.
Return to “Foundry Modo”
