Version 3.00 - Alpha10.1 (30.04.2016)
rwalker
Raoul wrote:Hi Ahmet,
Awesome work on v3.
I just wanted to mention a few small niggles that have only come up with this version... and see if it was just me and if they are fixable.
Firstly. My material previews have a high level of black pixelation going on. was fine in 2.25 but noise is clear in v3. Doesn't seem to respond to preview samples under 'other'.
R
You're not alone with the material preview black pixelation issue. Just so you know. R16.050 Studio.
abstrax
Awesome work on v3.
That looks like a bug on our side. Could you please send me a scene with a material that renders incorrectly in the preview? Thanks.
Polygons
With 3.0 releasing soon, will we have Deep Pixel support out of Octane for C4D on launch day?
Polygons wrote:With 3.0 releasing soon, will we have Deep Pixel support out of Octane for C4D on launch day?
Why not if that's accessible! But i'm in another deep waters now.
Raoul
Hi Abstrax, thanks for giving this your attention.
Here is a c4d file that just has a basic glossy gold material that has the noise in its preview.
Cheers
R
MATERIAL PREVIEW TEST.c4d.zip
Material noise preview
(326.84 KiB) Downloaded 260 times
abstrax
joecurrie wrote:
aoktar wrote:joecurrie,
i can't reproduce the problem on windows or osx. Can you save and send this scene? Also please try with latest A6.2
Hi Aoktar,
Please see attached scene and log this is now using Alpha 6.2.
In 3.00 alpha 8 I added a new release log flag rdStart which adds some additional logging during the startup of render threads. When Ahmet releases a new plugin based on alpha 8, it would be great if you could try to reproduce the problem with this log flag enabled and send me the files. Hopefully I will then see a bit clearer.
joecurrie
Hi Aoktar,
Hey Abstrax,
Thanks so much for looking into this, I'll do a test and send back some files/logs when the new plugin is released.
Mac OS X 10.11.4 - Cinema 4D R17 | Geforce GTX980 + 980ti | 32GB
Mibu
Hi, If volume with vdb are blended, some artefact appears. Is any chance how resolve it? Thanks.
atome451
Hi Aoktar,
For your information.
About the Octane Volume object and VDB import file. The import doesn't work if there is Extended ASCII characters in the path (under Windows 10 64bits).
By sample : "E:\Téléchargement\explosion.vdb" doesn't work but "E:\explosion.vdb" or "E:\Fichiers VDB\explosion.vdb" (with space) works fine.
I hope it'll be usefull.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
Mibu wrote:Hi, If volume with vdb are blended, some artefact appears. Is any chance how resolve it? Thanks.
Have you read standalone's release notes? Mentioned that there is a limit for aount of vdbs which can overlap.
Welcome to performance limitations of GPU development. I mean GPU not cpu. I hope makes some sense.
Return to “Releases”
