Here it worked with 2015.Gescort wrote:Hi, face!
All work, but render region stable crushed softimage.
But i haven´t tested it to deep. It should use the resolution from the camera view and the cropping is inside Softimage.
face
Ah yes, there must be an error, will try to fix it.face wrote:Here it worked with 2015.Gescort wrote:Hi, face!
face
Will check it also, thanks for report.Gescort wrote:After changed parameters (octane imager) rendered not continue, but begins first. It's not interactive.
Thanks it works nowface wrote: Ah, now i know it.
Have you installed the Microsoft Visual C++ 2015 Redistributable(X64)?
face
Ah, now i know it.wireframex wrote:
With which version of Softimage?wireframex wrote:Face
- Quick Render preview crash SI
- Need to replace all the shader with new ones from the last update to make a preview of the old scene
- Thumbnail of Material manager is not working like your last demo (only diffuse is working here)
Phil
