Octane for Softimage 1.03 RC1 [Obsolete]
Autodesk Softimage XSI (Developed by Face)
face
Im happy to release the next version after a long time.
Hope you will like it,
face
This is a major update, so many things are fixed, added or changed.
Some things are removed and not included.
ADDED:
  • New menu entries with which you can add/remove/inspect the Renderer from/to scene/pass/passes.
  • New menu entry to free the GPU memory.
  • The Shaderball is added again, with full support of compounds.
  • Shaderball quality uses the preference settings for quality.
  • New shader for the light profile is added, also the IES texture shader is changed to use the new profil shader.
CHANGED:
  • The Camera check/set is completely changed.
  • The Environment check/set is completely changed.
  • The GPU check/set is completely changed.
  • The Kernel check/set is completely changed.
  • The Output shader check/set is completely changed.
  • The Geometry check/set is completely changed and much faster.
  • The Shader generation check/set is completely changed and much much faster.
  • The Message system is updated to make it faster and to show critical warnings in red.
  • The Rendersystem is completely rewritten.
  • Render failure errors are now catched and shown.
  • The Octane log can now be shown over a button at any time.
  • The Octane node tree can be shown over a button at any time.
  • Image writing will now works in mutlithreaded. This will affect the generation and the image saving.
REMOVED:
  • Motion blur will no longer supported.
FUTURE CHANGES:
  • Instances will included soon.
  • PointClouds will included soon.
DOWNLOADS
MANUAL
INSTALLATION INSTRUCTIONS
  • Please follow the installation instructions in the on-line manual.
NVIDIA DRIVER REQUIREMENTS
  • This version requires video driver 337.xx or higher.
http://vimeo.com/user2509578
Elvissuperstar007
thank you for the work
wireframex
Thanks a lot
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
wireframex
Face
I have this pb in the Plugin Manager OctaneInternal64.dll is not found
Phil
Main Computer:
face
wireframex wrote:Face
Phil
Have you checked if the file is in the user folder?
C:\Users\xxx\Autodesk\Softimage_2015_SP1\Addons\OctaneForSoftimage64\Application\Plugins
The folder should contain this files:
eula.txt
history.txt
octane.dat
octane.dll
vcomp100.dll
version.txt
whats_new.txt
face
wireframex
I have checked and all the files you describded are in the folder
Maybe there is a conflict somewhere ... (I use 2015 SP2)
Main Computer:
face
wireframex wrote:I have checked and all the files you describded are in the folder
You have removed the 1.02 RC12?
face
wireframex
face
Yes
Main Computer:
face
face
Yes
Ah, now i know it.
Have you installed the Microsoft Visual C++ 2015 Redistributable(X64)?
face
Gescort
Hi, face!
All work, but render region stable crushed softimage.
Upd: after changed parameters (octane imager) rendered not continue, but begins first.
Return to “Autodesk Softimage XSI”
