Multi-passes don't line up [UPDATE: Still off on v2.22.2]
- fatfreemedia
- Contact:
Is there a stable 2.23 release with this fix yet?
Win10 64bit | 3 * GTX970 | i7 5930k | 32GB
Win10 64bit | 2 * GTX970 | i7 4790k | 16GB
Win10 64bit | 3 * GTX980 | i7 5930k | 32GB
Win10 64bit | 3 * GTX980 | i7 5930k | 48GB
Win10 64bit | 3 * GTX1070 | i7 6850k | 64GB
Hi Aoktar,
downloaded that project. Whatever you did definitely seems to have given a clean matte. Would be great if you could please explain what your process was, as it's not easy to tell. Thanks
-edit: Just did some experimenting. The render layer mask passes still aren't accurately matting out objects. I'm just trying to do a simple matting out of the sky in a scene, and it isn't working. The only way I can get it to work is by applying chokers to the mattes in post, which is far from ideal. I can imagine it's harder to generate a clean matte when there's motion blur and / or DOF, but right now a matte isn't even working on a shot without them. This is a feature I consider essential to the functionality of the render engine, so it would be really great to see this problem resolved ASAP.
Win 8.1 / i7 4930k / 2 x GTX Titan / Cinema 4d
I'm actually on 2.24.2 r2 and still have the "one-pixel-gap" issue between obects, using render layer.
Can someone give more updated news about the resolution of this problem?
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
It's not issue for plugin. Can you ask to Octane devs team?GIOLETS wrote:I'm actually on 2.24.2 r2 and still have the "one-pixel-gap" issue between obects, using render layer.
