Importing Alembic caches
Moderator: JimStar
Is there a way to get Octane to see imported Alembic caches? I can see them in the viewport, but Octane doesn't seem to be able to render them. I'm using this as a way to bring C4D Mograph animated components into Maya to interact with a scene I've set up in Maya.
Are somebody know is it possible to transfer bifrost particles to render it with Octane? I know i can export mesh with alembic, but i want to render foam to with Octane. Any different ways?
5x-Gtx1080 Ti+ 4x-Gtx 780 Ti, 2x-Xeon 2687W, 192Gb Ram
Don't think it's possible, there is a tool to convert the foam cache BIF files to Krakatoa PRT files*, that's all.
But Biffrost data are acessible for renderers in Maya API so maybe we will be able to render it directly in maya with the V3 of octane plugin.
*if you really need this, actually you can reimport the PRT files in a maya particle with PARTIO, and use octane plugin to export an instancer to standalone or using OpenVDB plugin to export to standalone V3.
https://knowledge.autodesk.com/support/ ... 8-htm.html
http://redpawfx.github.io/partio/
(Last version of PARTIO is for MAYA 2014)
Pascal ANDRE
one more step in standalone 3 alpha 7 to render foam particles, but not there yet :
"Introduced new sphere primitive, which can be used for particles. Support for motion blur and the ability to load/save from/to Alembic is still missing."
Pascal ANDRE
