Add materials with one click - toolbar
formatio
Hi
As I promised here is the toolbar (see attached file) - version 1.02.
Octane-Render-Toolbar-v1.02.zip
(249.69 KiB) Downloaded 409 times
Toolbar for octane 3.x.x plugin:
OctaneRenderv3.x_Toolbar-v1.01.zip
(257.59 KiB) Downloaded 301 times
Changelog for v 2.x
1.02
-added button to remove unused materials
-diff /spec material change from left to right mouse button
Changelog for v 3.x
1.01
-Added _ to all commands so it works in every language
How to install (included also in the archive):
Install for octane v3 is exactly the same procedure
1. Unpack Octane-Render-Toolbar.rui to temporrary location.
2. Move Rhino-Octane-Mats folder to your C:\ drive.
3. Open Rhino and go to Tools > Toolbar layout...
4. Window opens - go to File > Open... and point to Octane-Render-Toolbar.rui
5. In the same window select Octane-Render-Toolbar in the box called "Files"
6. You should see "Octane Toolbar" in the box below.
7. Uncheck it and check it if you cant see it in the main Rhino window.
8. Drag the toolbar by the blue stripe (not the tab title) and stick it next to the sidebar (best location imho)
If you want to change materials location on disk you have to change path in the toolbar itself via SHIFT+right clik on every button.
Any issues post here.
Reagards,
Mac
Fantastic - thanks for sharing Mac.
formatio
Hey,
I just realized that paths for the materials were configured for my windows user so for you to not edit anything in the toolbar I uploaded updated version 1.01
I updated the archive in the the first post
Regards,
Mac
prehabitat
formatio wrote:Hey,
Regards,
Mac
Thanks Mac,
I did a find/replace of macio->Andrew and solved it at my end... Did you substitute %appdata% or something? I wasn't sure if you could use explicit path (in quotes to allow the spaces in folder names) appended after global path/location (%appdata%).... I only have a fleeting knowledge of this stuff, likely got it all wrong but interested :)
P.s. Had planned to post here today letting you know about the path issue but you beat me to it :)
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
formatio
Hi
Unfortunately Rhino doesn't recognize system variables such a %appdata% - that would be perfect.
Regards,
Mac
formatio
New version 1.02 - added button to remove unused material + small bug fix - See first post in this thread.
Great work Mac.
prehabitat
formatio wrote:Unfortunately Rhino doesn't recognize system variables such a %appdata% - that would be perfect.
Perhaps a .bat installer which transfers the mats (via the system variable) and also changes the username part of the path in the toolbar file too? (Not sure if this is possible... I though Batch files could pass text edit commands directly via inbuilt text editor to rewrite files?)
Certainly not complaining; I really like it!!! I'll post my setup, I don't use the sidebar in the conventional way; but I did place it roughly as you suggested (right?) :)
EDIT: setup below; the properties, mats, octane, layers are on the second screen (cropped the rest off..)
neiwei845458454
Dim strObject, intIndex
strObject = Rhino.GetObject
If Not IsNull(strObject) Then
intIndex = Rhino.ObjectMaterialIndex(strObject)
If (intIndex = -1) Then
intIndex = Rhino.AddMaterialToObject(strObject)
End If
End If
ObjectMaterialIndex Example:
Dim strObject, intSource, intIndex
strObject = Rhino.GetObject("Select object")
intSource = Rhino.ObjectMaterialSource(strObject)
If (intSource = 0) Then
Rhino.Print "The material source is by layer"
Else
Rhino.Print "The material source is by object"
Rhino.Print "The material is default."
Else
Rhino.Print "The material is custom."
End If
End If
End If
neiwei845458454
Hi paul,
Can you do this like vray for rhino by apply material to objects?
-_visloadvismat "C:\ProgramData\ASGVIS\V-Ray Express\Rhino\Materials\Metal\chrome.vrmat"
-_visapplymaterial "/chrome"
Return to “Rhinoceros 3D”
