Version 2.26.1 (28.11.2016) - Obsolete Stable
najighassan wrote:hi beppe,
thanks for your reply.
i attached a image with both renders, its weird it literally just happened with the latest update.
hope you can help.
Can we see scene?
najighassan
Sure guys here is the scene...
Octane Test Scene_.zip
(1.62 MiB) Downloaded 344 times
najighassan wrote:Sure guys here is the scene...
Thanks. That's about render buffer type: Float. It's resulting linear(raw) output from renderer. LV display tonemapped by camera imagers. Is it clear for you? If you want same output use float(tonemapped). I don't know why it's different from default settings! Did you changed?
najighassan
Awesome, yes it works.
But i haven't changed it from the beginning so it was on default. Cause i never had that before.
But now its working. wicked.
Thank you so much for your help, appreciate your effort alot. And as i talk with others about it they all appreciate your quick turn around on everything alot.
Great stuff!!! ;-)
momade
hello aoktar.
all superb. works like a charm. i just can not find the render layers in LiveViewer any more... any hint? :DD
fuchsundvogel
activate renderpasses in rendersettings
momade
I must be so blind! can't find it...
underworldtr
The truth is out there...
C4D r18.048 / Octane Render Plug-in 3.06 / Turbulence FD (Build 1425) / X Particles 3.5
Titan X & GTX 1080
Win 7 Ultimate
momade
yes. for picture viewer rendering it works fine. i'm looking for the LiveViewer Render Passes Settings...
momade
Sorry aoktar.
I guess I have an issue here. Mayebe you can help...
I uninstalled EVERYTHING that had to do with otoy or octane to make a clean cut.
reinstalled the c4d plugin und it works without SDK...
here is a console screenshot:
there are NO files in any OTOY folder on my system. still octane for c4d works alone and i still have no render passes option in LiveViewer:
Return to “Releases”
