Can we see scene?najighassan wrote:hi beppe,
thanks for your reply.
i attached a image with both renders, its weird it literally just happened with the latest update.
hope you can help.
Version 2.26.1 (28.11.2016) - Obsolete Stable
- najighassan
Sure guys here is the scene...
- Octane Test Scene_.zip
- (1.62 MiB) Downloaded 334 times
Thanks. That's about render buffer type: Float. It's resulting linear(raw) output from renderer. LV display tonemapped by camera imagers. Is it clear for you? If you want same output use float(tonemapped). I don't know why it's different from default settings! Did you changed?najighassan wrote:Sure guys here is the scene...
- najighassan
Awesome, yes it works.
But i haven't changed it from the beginning so it was on default. Cause i never had that before.
But now its working. wicked.
Thank you so much for your help, appreciate your effort alot. And as i talk with others about it they all appreciate your quick turn around on everything alot.
Great stuff!!!
Great stuff!!!
hello aoktar.
all superb. works like a charm. i just can not find the render layers in LiveViewer any more... any hint? :DD
- fuchsundvogel
activate renderpasses in rendersettings
I must be so blind! can't find it...
- underworldtr
yes. for picture viewer rendering it works fine. i'm looking for the LiveViewer Render Passes Settings...
Sorry aoktar.
I guess I have an issue here. Mayebe you can help...
I uninstalled EVERYTHING that had to do with otoy or octane to make a clean cut.
reinstalled the c4d plugin und it works without SDK...
here is a console screenshot: there are NO files in any OTOY folder on my system. still octane for c4d works alone and i still have no render passes option in LiveViewer:
